Discussion topic: Pixelated sky movies
Message posted on 26 Apr 2023 12:32 PM
Having problems with most sky movies channels bein pixelated. Can anyone help. Have already rebooted several times.
Message posted on 26 Apr 2023 12:47 PM
Re: Pixelated sky movies
Hi @Su321
You could try a Reset Settings in the Q box hidden menu.
If the issue continues best to contact Sky for an Engineer to check your dish alignment
