Discussion topic: Philips 43PUS8949/12 Sky remote unable to change inputs
Message posted on 06 May 2025 11:13 PM
Message posted on 07 May 2025 11:29 AM
							Re: Philips 43PUS8949/12 Sky remote unable to change inputs
Hi @TVwatcher42
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation. The invite will automatically close if not responded to within 48 hours.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 07 May 2025 12:39 PM
Message posted on 07 May 2025 01:53 PM - last edited: 07 May 2025 01:54 PM
@TVwatcher42 wrote:
How likely is it that Sky will fix this
That's typically down to the inconsistent ways in which different television manufacturers have implemented input switching rather than something Sky can be expected to 'fix', particularly on Sky Q which is approaching the end of its life as a platform.
Message posted on 07 May 2025 06:59 PM
Thanks for letting me know. Hopefully a solution can be found - but if not, then it'll be just 'one of those things' I guess.
Cheers
Message posted on 07 May 2025 08:44 PM
Cheers
@TVwatcher42 when you currently change the source with your tv remote when you reach the source that you want ie say HDMI 2 to you have to press select/ok or another button to confirm your selection. If so then afraid the Sky Q remote will not work at all.
The Sky Q remote only work on source selection where after landing on say HDMI 2 it automatically selects this source after being on it for 3 or more seconds
hope that makes sense
