cancel
Showing results for
Search instead for
Did you mean:
Peloton app not opening
SOLVED
SlenderRobert
Level 11
Re: Peloton app not opening
@FranLouise wrote:
The Peloton App will not open. Just a blank black screen
It's the universe telling you that you don't need to exercise today.
Cinnoir
Level 1
Hi @Chloe-W22 my Peloton app continues not to work. The main issues are:
1) I log in and once I press submit, it cuts out and brings me back to the Sky homepage
2) I select the Peloton app and it goes to a black screen so I don't even get to the log in page
This is incredibly frustrating and has been happening for at least 3-4 weeks with no improvement.
Rugbyball
Level 1
i have been told by sky help that the app will be removed from Sky Q IN MAY - is this correct - rather than fixing an issue you are just removing it?
SlenderRobert
Level 11
It may actually be Peleton that are removing the app, not Sky.
According to their approved device list, Sky Q is not listed:
The Peloton App is available on web and for the iPhone, iPad, Android phones, Android tablets, Fire tablets, Android TV, Apple TV, Fire TV, and Roku TV.
Smerc101
Level 1
Message contains an image
Clearly didn't read properly. It clearly stres on Peloton it is available on SkY Q (UK)
SlenderRobert
Level 11
That appears to be an out-dated link to the US site. Can you find the same info on the UK site? I can't. Not that I care. I've no intention of ever using Peloton.
Zoe+Mountier
Level 1
Hi is there a solution for this, I have the same issue, peleton app not loading and going back to sky screen.
Smerc101
Level 1
Solution for iPhone and iPad users who have a smart TV. Connect you phone to your TV via Bluetooth.
select your workout through the peloton app on your phone and then select the below circled in red  and you should be able to stream to your TV.
you can charge your device at the same time whilst doing your workout.
Smerc101
Level 1
If you have zero interest go and find something more productive to do than annoy everyone! The information is up to date and for the UK!
Smerc101
Level 1
Hi @Zoe+Mountier
see my other post on how to connect to your smart TV using your iPhone of you have these devices.
SimonPT
Level 1
@Smerc101  - on my smart TV, I only get audio, no video if I share from my iPhone, so no help unfortunately.
best+of+the+best
Level 11
Fair comment @Smerc101 but if it's a smart tv just download the Peloton app if available for your TV
Sorry don't do apple unless in fruit bowl or fridge good post though
Smerc101
Level 1
See below you connect via iPhone
Select Airplay and then scroll to your TV and select. It should then stream to your screen
Smerc101
Level 1
@SimonPT See my latest comment
SlenderRobert
Level 11
Message contains a hyperlink
@Smerc101
Your solution relies entirely on a customer having an Apple device and a smart TV capable of receiving audio & video via Airplay. Not everyone has that.
It appears that Peloton are no longer advertising or supporting Sky devices with their app. There is no mention of it on their website, even though the app is still currently available on Q, Glass & Stream.
There current app supported devices are detailed here:
https://support.onepeloton.com/hc/en-gb/articles/360041841611-Streaming-Peloton-Classes-On-Your-TV
