4
This discussion topic has been answered Discussion topic: Peacemaker, first episode. Only seems to be a two minute trailer.
This message was authored by: ShirleyAnne62
Hi, I am trying to watch the first episode of Peacemaker on demand. However despite it promising to be a 59 minute episode, when downloaded it seems to have morphed into a two minute trailer. How can I get to see the actual episode?
This message was authored by: xenon81 Answer
Re: Peacemaker, first episode. Only seems to be a two minute trailer.
I've just downloaded it and it's definitely the full episode, not a trailer. Try deleting the trailer, and then deleting it from the Deleted section so it's fully gone, and then downloading the first episode again.
@ShirleyAnne62
If you do a search there appears to be two versions - the 2 minute trailer that you have found and the 53 minute version of the episode.
Avatar for ShirleyAnne62
Thank you for your answer, but even using the search facility, it looks like it is the whole 53 minute episode until you click on it...and then it becomes the two minute trailer again.
Thank you, did that and it worked...problem solved!
