139
This discussion topic has been answered Discussion topic: Pause / rewind issue 16/09/25
Re: Pause / rewind issue 16/09/25
I'm still having this issue. It's not happening on all channels though.
Confetti Ring
Avatar for Daniel0210
Level 16 icon
Re: Pause and rewind not working on most channels.... suddenly started this evening!
@MEH4
I have moved your post into the thread discussing this. Sky are aware. Please see the post currently marked as the answer.
This message was authored by: CSH123456
It's doing it again, it has been alright since a couple of days ago but is now not pausing or rewinding.
This message was authored by: mark+p+melaugh
I'm now having the same problem can't pause or rewind live tv  18 September 2025
This message was authored by: SJcm1
Live pause only working on some channels
My son is severely autistic and when he pauses bbc1 and other channels ( not all ) the tv Gide is showing program from hours ago
This message was authored by: Jwilliams61
Re: Live pause not available
Hi the problem was fixed a few days ago but as of this morning 18th it has stopped working again. Can you advise please?
This message was authored by: dlc
Still having issue tried the switch on and off fix to no avail
Confetti Ring
Level 16 icon
@mark+p+melaugh
As per the advice given in the post currently marked as the answer have you rebooted the box?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: LizJD
Pause /rewind issue again 18th Sep
Ca not pause or rewind ljve tv.  This happened before on 16th and was sorted by Sky but has nkw happened again.  Come on Sky engineers.  Get it fixed please
This message was authored by: Trophy77
Sky+ box still won't pause rewind or record rebooting does nothing. 18th at 7.22am.
Record Emmerdale every episode and it showed Emmerdale was still on and it was still recording at 10.30 when we switched it off last night. Seems others had the same issue with other channels not displaying in the box at the bottom of the screen what was actually on.
Also still says that Emmerdale is still on and started 713 minutes ago 🤣🤣🤣
Same here it's frustrating
hi everyone.
We know that the problem with Pause & Rewind on some channels  (& also problems with CBBC/CBeebies)  has occurred again on Thursday 18th September, & we have reported to SKY & any updates will be made when possible.
This message was authored by: susan+broadhead
Re: SkyQ Pause not working
Will I be informed when this pause/rewind fault is corrected? Or do I need to keep checking my TV?
As mentioned by others I have found it's working on sky channels but not BBC and ITV.
hi @susan+broadhead
There will be a reply on this discussion when it it is confirmed fixed, so if you get notifications you should be advised.
That said formal confirmation may be a short while after it has fixed so you may be able to use this before being notified.
Answered - Go to Answer
