156
This discussion topic has been answered Discussion topic: Pause / rewind issue 16/09/25
Re: Live Pause not working on Sky +
@LQ2 wrote:
Hi, i am not able to pause or rewind most channels on my Sky plus box this morning.  It was working yesterday.  I seem to be able to pause Gold channel ok.  The on screen message says to call the Broadcaster.  I followed the online instructions to rebuild the box but still not working.  I havent tried the full reset as i would lose all my recordings.  Is there anything else i can try?  My sky + box is old and i am only able to record certain certains as i lose the signal.  If i ring Sky what would they do?  WIll i have to do the full reset? Many thanks
hi @LQ2
As you will see I have moved your post onto another (in the SKY Q board) discussing this - please see the reply currently marked as Answer to advise SKY are now aware
This message was authored by: Jon+Curtis
Re: Sky q will not pause rewind Live tv
Looks like it's only the main BBC and ITV channels
This message was authored by: Umiamz
No, I've tried lots of different channels and they are all having this issue other than Sky's own channels which seem to be pausing and rewinding for me.
I also tried CBBC, which showed for a few seconds then changed to a screen saying that "no programmes were currently being shown on this channel" or words to that effect.
Clearly a Sky issue, so we just have to wait until they fix it.
@Jenny+wwh wrote:
Yes getting the same problme here in Devon.
Done a reboot.
Pause / rewindo only worlking for recordings now.
Samsung TV - not that that shoudl make any difference..
This was definatly an overnight thing - so maybe a dodge update -
Software Version showing is
Q320.000.15.ooL (62axucc0
That version isn't new
@Dove+Cottage wrote:
I have same problem live tv will not pause, a screen message says I cannot pause, rewind.
did sky q box reset then paired remote ok but still cannot pause live tv.
my LG remote pause button does exactly the same.
The LG remote is controlling the TV's freeview tuner or controlling the Q box?
This message was authored by: johnmunro
Can’t pause or rewind
Can't pause or rewind some channels on sky q box
This message was authored by: Jenny+wwh
Seeing same issue on only some  channels tested
Film 4HD works as normal
GB News does not pause.
This message was authored by: LQ2
Re: SkyQ: Live pause not working for channels 101-105
Thanks but it is a Sky + box i have not Sky Q.
This message was authored by: RA30
Live pause not available
Any reason my live pause has just stopped working
Re: Can’t pause or rewind
@johnmunro I've added your post to an existing thread on the subject. As you can see from the post marked as the Answer, Sky are aware.
@LQ2 the same fault is affecting both Sky Q and Sky+.
This message was authored by: Drrotcod
Re: Live pause is not available
Have sky+ and live pause not available- have tried unplug and sky+ rebuild and not helped
Thank you
This message was authored by: Dove+Cottage
Mine has started to work now...
someone fixed this??
This message was authored by: AnnieMac67
Re: Pause / rewind issue 16/09/25
Hiya  .. that's great .. thank you .. I thought they'd done some sort of update  .. hopefully they'll get it sorted soon 🙂
Answered - Go to Answer
