Discussion topic: Paramount+ in 4K/HDR
Re: Paramount+ in 4K/HDR
@hrai wrote:
@Laing1
The app on my Samsung lists both HDR10 and Dolby Vision for HDR formats suggesting that it could be available via Sky Q?
@hrai but unfortunately Dolby Vision will never be available on Sky Q as the box is not capable of handling that format
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Nigelb1972
I've just checked both the Stream App and native app on my Samsung QLED and Sky Stream shows Dolby Vision and Atmos and the TV shows HDR10 and Atmos but neither play HDR so I'm guessing the file formats are there but subject to subscription levels.,
Fyi you can now upgrade to Paramount+ Premium through Sky Stream but the extra bit is billed separately to a bank card
This message was authored by: William+Blackley
Hi folks,
I believe I know what the issue is with the Paramount+ app not showing 4k uhd content on Sky Q.
It's because all Sky q uhd boxes only support hybrid log gamma HDR and will not play Dolby vision , hdr10, etc
Also, assuming you have a 4k hdr tv (which should be fine), you will need to have the right hdmi cables....they need to be hdmi 2.1 or later.
personally, I only watch Sky uhd hdr content via my Sky q box and subscribe to all other apps via my smart tv, which supports all formats of hdr, and I have no issues watching any 4 k uhd hdr on any of the apps.
best wishes, Bill.
@William+Blackley wrote:
Hi folks,
best wishes, Bill.
@William+Blackley
The SKy Q boxes do support HDR10 as well as HLG - they don't support DV
It is SKY UHD content that only uses HLG (as welll as Iplayer - the same as on other devices)
Netflix, Disney+, Amazon Prime all use HDR10 on their apps on SKY Q
Hi folks,
best wishes, Bill.
@William+Blackley
Although I have no way of testing it as I do not have the 4K upgrade for P+, I believe the P+ does indeed now also have 4K HDR using HDR10 on SKY Q
It may be worth noting that your post was on an old discussion regarding the Paramount + app on SKY Q before P+  subscription upgrades to 4K were available via SKY
This message was authored by: 15Hatfield
I can confirm if you have a premium account and log into the Paramount + app on the Sky Q box Dolby vision tagged content plays in HDR10 (And Dolby Atmos too if it has it.
As tested with Quiet Place 2.
