Discussion topic: Paramount + buffering and sky box making a fan noise
This message was authored by: Clark1978
When watching paramount, it's ok for 20 mins then it starts to buffer, it still plays but the screen goes darker and the wheel of death spins, the box then starts to make a loud fan type noise which will only stop when I turn it off at the mains. No other app does this however Betflix can take an age to load, even having to go in and out of other apps before Netflix will load.
This message was authored by: Tom-W19
Re: Paramount + buffering and sky box making a fan noise
Hi @Clark1978
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Hi @Clark1978
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
This message was authored by: oxobox
I have exactly the same issue Paramount + only causing this issue
This message was authored by: living+my+life+my+way
We are having exactly the same issue, worryingly the fan doesn't stop once you move off of Paramount.  Is there a solution? We surely dont need to keep unplugging the unit from the mains?
Avatar for Clark1978
I had an engineer come out and fitted a new box, it still buffers on paramount but the fan doesn't come on, we've recently had full fibre installed so he told me to speak to the broadband tech team, Netflix just through us out yesterday and 4 times since full fibre was fitted the phone line has been down so internet has been off, I reset the router then it's fine. I'm phoning them today because it's ridiculous.
Threw* not through
Hi @living+my+life+my+way Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
Yes we have done this , frequently but as soon as we go back onto Paramount the fan starts up again and doesnt go off. its not in an enclosed cupboard and nothing is in the way of the vents so probably need to raise if with sky themselves. Thanks anyway
This message was authored by: targetlk
I'm having the same issue
and it seems sky don't have a solution for this
and sem to close all enquires down
we need a solution asap
This message was authored by: LB57
This exact problem is the same for me.  I reported it last year with Sky technical team,  They de-installed my App and re-installed it.  It lasted for about a week and then the buffering and the continuous Fan kicked in again.  Like you it only happens with the Paramount + App.
I reported it again and they arranged an Engineer visit.  He tried the app himself and it began buffering straight away and as always the fan kicked in and the only way to stop the fan is to disconnect at the mains.  The Q box didn't  get hot but I was always reluctant to go to bed with the fan churning away.  It's a real pain if you're recording anything as it interrupts that of course.  The Engineer replaced the hard drive which then meant I had to re-initiate all my Apps.  Unfortunately, it didn't solve the problem long term.   I just avoid Paramount + where possible but I've just been watching a series that was a sky original and only aired from Paramount + after episode 1.  It is still a problem and the buffering keeps happening and last night after watching just 2 episodes the fan kicked in and I had to turn off at the mains.  Nightmare and time a fix wad sorted.  @Clark1978 @targetlk @oxobox
It's not a hardware issue as I had a box replaced
it's a software issue
next step has to be trying to remove soo and update software etc
I also think it's a rushed not well designed app
tried soo hard to copy Netflix etc
Coding etc isn't up to to scratch
the headache though is for some people it works fine
wonder also if it's designed to be more compatible with sky glass and they designed it with that in mind and so sky Q will always have issues which will get worse and worse as they focus more and more on the  gimmick that is sky glass
This message was authored by: NigeB2
Exact same problem here. Fan goes on full after using Paremount+.
is there any way to remove ONLY the Paramount+ app without a complete settings reset?
I'd happy do without Paramount + to avoid this problem with the fan coming on permanently.
Just don't use it?
A "Refresh Apps" will reinstall all the apps without touching anything else.
Not noticed this problem but I can't remember the last time I used P+ I'll have to give it a try. Does sound like bad software.
Thanks for that. Refreshing the apps is not a bad idea. But it will only help if Paramount + have fixed their app recently. I'd prefer to simply remove it.
This problem definitely seems more prevalent on Sky Q boxes and not other Sky devices.
