Discussion topic: Paramount Plus won’t play stuck at 7 seconds to go on adds then error 3005
This message was authored by: pandoramaw
Message posted on 29 Jun 2025 02:11 PM
Since Friday Paramount plus, loads and you select which show you want to watch - advert runs up to 7 seconds to go then error 3005 all shows .
This message was authored by: Samodowd
Message posted on 29 Jun 2025 04:40 PM
Re: Paramount Plus won’t play stuck at 7 seconds to go on adds then error 3005
Is there a solution to this? Ours is the same!
