Discussion topic: Panasonic TB-40S45AEY won't connect to sky remote
Message posted on 27 Feb 2025 12:08 PM
Hi, bought this cheap TV (Panasonic TB-40S45AEY) for our bedroom and have tried connecting via standard set-up (1&3, codes offered) but it says the model isn't listed and then all panasonic option codes don't work. I then try Vestel and it didn't like the 3 options offered there. Any ideas as would like to be able to use I remote if possible.
Message posted on 27 Feb 2025 01:06 PM
Re: Panasonic TB-40S45AEY won't connect to sky remote
@KP7410 have you tried the options under other
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 27 Feb 2025 01:18 PM
Hi, do you mean other as in other brands?
Message posted on 27 Feb 2025 01:37 PM
so i type in other in the TV brands element and clickec enter and it said you can't connect - so basically no options came up
