Discussion topic: Pairing my viewing card on Sky Q
Message posted on 01 Aug 2024 07:39 PM
I have just got a new Sky Q box I know it says pairing can take up to 4 hours, but my Sky Q box keeps resetting itself after about 10 minutes so I have to keep going through the process.
How will I know if its the card or the box at fault?
Thanks for any help
Message posted on 01 Aug 2024 07:43 PM
Re: Pairing my viewing card on Sky Q
Thanks for any help
Hi @Jools24
