Discussion topic: Pairing Sky Q remote with new Polaroid Roku P55UR1953U tv
Message posted on 22 Nov 2023 04:03 PM
Struggling to pair Sky Q remote to new tv. Tried the usual instructions, but no option for Polaroid Roku P55UR1953U tv. Help!
Message posted on 22 Nov 2023 04:12 PM
Re: Pairing Sky Q remote with new Polaroid Roku P55UR1953U tv
Hi @HT2
Have you tried selecting Other brands in the pairing Setup?
Try completly resetting your Bluetooth remote.
Message posted on 22 Nov 2023 05:02 PM
Thank you, this has paired some of the functions ie on/off and volume, but still unable to scroll up and down or select from the menu.
Message posted on 22 Nov 2023 07:56 PM
Hi @HT2
When the Q remote is paired with a TV the only TV functions it will operate are:-
- TV On/Off (with long press)
- Volume Up/Down
- Mute
- TV Input (Multiple presses should scroll through the TV HDMI and other inputs)
No other buttons will operate the TV.
So no scrolling and No Select option.
