Discussion topic: Pairing Sky Q remote with TCL Fire TV
This message was authored by: Graham121212
Re: Pairing Sky Q remote with TCL Fire TV
Toshiba 9 worked ok but seemed to interfere with my daughters infrared lights in her room. Toshiba 10 also worked without the interference. Model was TCL 32SF540K
This message was authored by: Marcus_M
Hi There,
I had this same issue and just solved it using Toshiba setting i think option 9 on the remote discovery but try a few either side of that.
Hope you crack it. It took me a while.
Marcus
This message was authored by: Jacko456
Thank you that solved the issue.
This message was authored by: Yummyyumzone
Hi peeps
ive been trawling the net to try and link my sky remote to the tcl 32SF540k. I've been going round it circles   I've tried TCK/toshiba/jvc but still can't get it to work with my tv? Any ideas?
I would retry all Toshiba ones personally and test thoroughly. It want thru most brands over a few hours before landing on Toshiba
This worked for me. Thank you
This message was authored by: Tom+Culpin
Toshiba 9 worked for my TCL32SF540. Thanks to everyone for their input here. Much appreciated
Thank you.  That has worked on both my TCL tvs
This message was authored by: Solfer
I have exactly the same model TCL, but it refuses to recognise any Toshiba, Vestel, JVC or TCL code... Unbelievably annoying, knowing it works for others here!
