Discussion topic: Pairing Sky Q remote with TCL Fire TV
Message posted on 09 Nov 2024 10:16 PM
Re: Pairing Sky Q remote with TCL Fire TV
Toshiba 9 worked ok but seemed to interfere with my daughters infrared lights in her room. Toshiba 10 also worked without the interference. Model was TCL 32SF540K
Message posted on 11 Nov 2024 06:25 AM
Hi There,
I had this same issue and just solved it using Toshiba setting i think option 9 on the remote discovery but try a few either side of that.
Hope you crack it. It took me a while.
Marcus
Message posted on 11 Nov 2024 06:29 AM
Thank you that solved the issue.
Message posted on 23 Nov 2024 10:21 PM
Hi peeps
ive been trawling the net to try and link my sky remote to the tcl 32SF540k. I've been going round it circles I've tried TCK/toshiba/jvc but still can't get it to work with my tv? Any ideas?
Message posted on 24 Nov 2024 04:49 AM
I would retry all Toshiba ones personally and test thoroughly. It want thru most brands over a few hours before landing on Toshiba
Message posted on 15 Jan 2025 11:31 PM
This worked for me. Thank you
Message posted on 26 Jan 2025 01:36 PM
Toshiba 9 worked for my TCL32SF540. Thanks to everyone for their input here. Much appreciated
Message posted on 26 Jan 2025 02:20 PM
Thank you. That has worked on both my TCL tvs
Message posted on 15 Mar 2025 08:09 AM
I have exactly the same model TCL, but it refuses to recognise any Toshiba, Vestel, JVC or TCL code... Unbelievably annoying, knowing it works for others here!
Message posted on 22 Dec 2025 02:19 PM
OH JOY!!!
After 2 weeks of trying every code under the sun for my TCL 32SDF560, I asked SKY for a new remote. It arrived withinn 48 hours. Bizarrely, it takes me to a different setup menu than the old remote did. I used the new "find the code for me" option. On 5th attempt...IT WORKED! Remote rage now over. If you'r struggling to pair your remote, order a new one and you will be as happy as I am!
