Discussion topic: Pairing Sky Q remote with TCL Fire TV
Message posted on 03 Jan 2024 12:59 PM
Hi all, first time poster. I'm trying to pair my Sky Q remote with my new TCL Fire TV (model 40SF540K) without success. I've tried the suggested 4-digit codes for TCL (2703 & 3075), but they don’t work. I also tried all 25 JVC codes after reading another post. Have tried both my voice and non-voice remotes, both paired fine with my Samsung TVs. Can someone pls help? Thanks!
Message posted on 03 Jan 2024 01:54 PM
Re: Pairing Sky Q remote with TCL Fire TV
@RayV is this a bluetooth remote ie one with a voice button on it ?
Message posted on 03 Jan 2024 04:53 PM
Hi @Laing1 thanks for replying. Primarily it's the standard (non-voice) Sky Q remote, which came with my mini box, that I wanted to pair. I tried multiple 4-digit codes but none worked. I then also tried the Sky Q voice remote from my other TV, but again no luck. Both remotes paried fine with other TVs.
I'm also sure the TV itself is not Bluetooth-only in terms of receiving, as it has IR on the remote and TV set, and also didn't swith off when the sensor was covered.
Appreciate any suggestions you can provide. Thanks.
Message posted on 03 Jan 2024 05:06 PM
@RayV you could try vestel codes I recently bought a Toshiba fire TV for a bedroom and was able to pair the bluetooth remote to that using the Toshiba codes so may give them a try as well
Message posted on 03 Jan 2024 05:07 PM
Thanks @Laing1 I will give that a shot when I get home, and let you know!
Message posted on 05 Jan 2024 01:45 PM
Hi @Laing1 just to let you know that unfortunately the Vestel codes didn't do the trick. Thanks all the same for your help.
If any other suggestions out there, would be most grateful.
Message posted on 05 Jan 2024 02:01 PM
@RayV did you try the Toshiba codes ?
Message posted on 08 Jan 2024 10:56 AM
Hi @Laing1 sorry late reply. Yes, tried the Vestel and all the Toshiba codes, but no luck.
Also messaged TCL directly last week; no repsonse as yet.
Thanks v much for your help!
Message posted on 19 Apr 2024 07:10 AM
Hi had the exact same problem and found the solution by looking at a number of sites, go to the set up remote control menu, enter the brand JVC, then press find it for me, will give 1-27 settings, try each one, mine worked on option 17. Hope this works for you 🙏
Message posted on 12 May 2024 08:38 PM
Hi, was the JVC you referred to inplace to enable the TCL to pair with sky q or have I misunderstood?
thanks
Ron
Message posted on 08 Aug 2024 02:07 PM
Hi, did you solve your issue and find the code? If so, could you please share it as I'm having the same issues. Thank you
Message posted on 12 Aug 2024 12:27 AM
Tried using setting for JVC took it slowly as seems to take a little longer to respond to volume, but worked on setting 18
Message posted on 12 Aug 2024 08:26 AM
Hi Ron, Yes i used the JVC codes to pair my TCL to the sky remote, when pairing take a few seconds on each code using the volume buttons, mine worked on code 17 and another post said there's worked on code 18. Good luck!!!
Message posted on 26 Aug 2024 05:35 PM
Hi and thanks all, sorry for late response. Sadly it's still not working for me on my Amazon Fire TCL, so still having to use two remotes 😞
Message posted on 24 Sep 2024 08:17 PM
I've just bought a Amazon fire tv . And the engineer tuned the sound volume to TCL works fine on sky Q remote and sound bar remote.
