Discussion topic: Our sky subscription does not seem to run Netflix or prime. Everything else is working though.
This message was authored by: Garydon
When we try to run, Netflix or Amazon Prime through sky, it does not seem to load
Re: Our sky subscription does not seem to run Netflix or prime. Everything else is working though.
Hi @Garydon
It might be worth just trying a box reboot before the reset procedure...
