Discussion topic: Our Sky Q box is showing NO Sky channels. Displays a message to check we have the correct subscrip
Message posted on 13 Mar 2024 06:42 PM
Message says check we have the adequate subscription ( which we have) and our main box is fine. Have switched off at the mains and reset a few times but remains the same
Message posted on 13 Mar 2024 07:04 PM
Re: Our Sky Q box is showing NO Sky channels. Displays a message to check we have the correct subs
Hi @Alison42
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
