Discussion topic: Others piggybacking in apts on my sky connection
This message was authored by: KMN
Can no longer record programmes as other apts seem to be connected to my sky box
Re: Others piggybacking in apts on my sky connection
Hi @KMN   How do you know that others have connected to your Sky Q TV box?
And why would that stop you recording?
It seems vanishingly unlikely unless your wifi password is easily guessed and they also have sky minis just lying around waiting for this opportunity.
Avatar for KMN
Press record before I go out and quite often it fails due to technical fault?
@KMN
Your reply still doesn't indicate a third party is involved.
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
