Discussion topic: Orange light will not change to green
Message posted on ‎22 Mar 2025 10:21 AM
I have disconnected power and left it off for 10 minutes and tried again, still nothing changed
Message posted on ‎22 Mar 2025 10:23 AM
Re: Orange light will not change to green
Hi @Rusty51 To rule out a problem with the remote, try pressing the power button on the box itself.
Message posted on ‎22 Mar 2025 11:43 AM
Power button not working. But thank you for your assistance. They are going to send a new box out. Rusty52
Message posted on ‎22 Mar 2025 11:48 AM - last edited: ‎22 Mar 2025 11:49 AM
Hi @Rusty51
If you have ordered a new Q box this usually means a doorstep swap.
Don’t forget to keep your viewing card from the failed box.
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on ‎24 Mar 2025 08:20 AM
Will do, thank you for the information. Rusty51
