Discussion topic: Only f1 channel not recorded on sky Q
This message was authored by: Shelley2000
Hello
i have subscribed to F1 sports only.  I recorded race and it has not recorded and says I do not have a subscription
Re: Only f1 channel not recorded on sky Q
@Shelley2000 wrote:
Hello
hi @Shelley2000
Is it possible you set to record from the Main Event channel that often also carries it ?
Although it may not be convenient there are replays this afternoon on the F1 channel.
If you do record this afternoon's replays be aware the last overran  & it is possible that the listings do not reflect this so I would suggest you also record the following programme(s)
Edit: BTW If you do not have the UHD add on make sure you select the HD version of the  F1 channel
