Discussion topic: One of my sky mini boxes keeps freezing and disconnecting from the q box. .
This message was authored by: Lottie128
one of my sky mini boxes keeps freezing and disconnecting from the sky q box. I have checked and they all have the latest version and I've tried rebooting the q box and the mini box.
Re: One of my sky mini boxes keeps freezing and disconnecting from the q box. .
Hi @Lottie128
Try a Network Reset on the mini.
If the connected mini is nearest to the problem mini then you can use the WPS on that
