Discussion topic: One of my sky boxes has a technical fault
This message was authored by: JamesTucker
One of our sky q boxes is displaying technical fault! We have reset the box and still no picture
Re: One of my sky boxes has a technical fault
Hi @JamesTucker Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
