Discussion topic: One of my mini boxes won’t update software. It says there is a problem with this sky box! Any sugges
This message was authored by Titans This message was authored by: Titans
One of my mini boxes won’t update software. It says there is a problem with this sky box! Any suggestions please??
This message was authored by ThePope27 This message was authored by: ThePope27
Re: One of my mini boxes won’t update software. It says there is a problem with this sky box! Any su
Hi @Titans
I would recommend factory resetting your mini box, I have put the instructions below to do this
To reset your Sky Q mini box you need to access the hidden menu, press the Home button and then navigate down to the Settings option without selecting it. Once Settings is highlighted, press 0 0 1 and then the Select button. Go down to "Reset" and Perform the "Facotry Reset", as this is a mini box you won't loose your recordings as these are saved on the Main Q Box. you'll need to re-pair your Bluetooth remote if you use one. If you can't turn on the mini box with the remote after the Reset, press the Standby button (indicated by an Amber LED) on the front of the box. To re-pair the remote, press 1 and 3 together on the remote and follow the on-screen instructions, it will then ask you to connect your Mini Box back to your Main Box, once this is complete try and initiate a Software Update again.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
