Discussion topic: One of my mini boxes is showing Technical fault. This isn’t first time in recent weeks
This message was authored by: Stuart24
The mini box shows technical fault and can't watch tv.   Have rebooted and get same message.  All other mini boxes working.  I can see tv guide so box isn't getting signal
Re: One of my mini boxes is showing Technical fault. This isn’t first time in recent weeks
Hi @Stuart24
Did you reboot your Main Q box before rebooting the mini.
Reboot the mini as above.
Avatar for Stuart24
Thank you.   I've rebooted the mini box a few times and at last I have made progress.  Only thing is that when I change channel it's taking 10 seconds to change which has been an issue for weeks , plus I've been losing connectivity for some channels
