2
This discussion topic has been answered Discussion topic: One of my mini boxes is not working, I’ve tried rebooting the hub and nothing
This message was authored by: Red45
Hi one of my mini boxes is not working, I've tried switching everything off and nothing
Re: One of my mini boxes is not working, I’ve tried rebooting the hub and nothing
Hi @Red45
First try rebooting the main Q box again and then when this is completely back up and running reboot the problem mini
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Hi @Red45
Avatar for Red45
Thank you I did what you said all working now 😊
