Discussion topic: One minibox will not connect to the main box
Message posted on 31 Jul 2024 09:41 AM
I have tried all the steps I have found in the guides and still cannot seem to get the minibox upstairs connected to the main box which is located downstair. Is there anything else I can try?
Message posted on 31 Jul 2024 09:43 AM
Re: One minibox will not connect to the main box
hi @Marsh2503
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
