2
This discussion topic has been answered Discussion topic: On my multi room TV it's says (You can't watch TV at the moment as there is a connectivity problem)
This message was authored by: Redmen72
I can't watch TV upstairs but I can watch YouTube
This message was authored by: Laing1 Answer
Re: On my multi room TV it's says (You can't watch TV at the moment as there is a connectivity probl
@Redmen72 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
then
Avatar for Redmen72
Yes, tried that and it worked so thanks. Must have had a moment 🫣🫣 cheers 👍👍
