Discussion topic: On demand and catchup "upgrade subscription" error message
Message posted on 08 Mar 2023 09:01 AM
New Q box, on demand and catchup not working, with upgrade subscription message.
Ive updated software and set download quality to SD with no success.
This appears to be a common problem, why no easy fix?
Message posted on 08 Mar 2023 09:46 AM - last edited: 08 Mar 2023 09:46 AM
Re: On demand and catchup "upgrade subscription" error message
hi @Jon431
unfortunatley, as you suspect, I think you are suffering from a bug at SKY's end which can affect some new customers when trying to download.
I have escalated your post to SKY who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
I believe they try to refresh the card which sometimes works first time but I think it can take several attempts and even then sometimes it needs some other background process
If you are using Safari I believe you must make sure that 'Hide IP adress' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Although it may not seem like it, it doesn't affect all new customers & generally a quick refresh of signals does seem to cure it for most people
Message posted on 08 Mar 2023 09:48 AM
Hi there, thank you for escalating this. We have sent an invite to Jon431.
Message posted on 08 Mar 2023 10:17 AM
Update-We are closing this session now as this matter has now been resolved. If there is anything else we can help you with, please do not hesitate to reach out. Thanks.
Message posted on 26 Jul 2023 05:44 PM
Hi,
I've been having this problem with our skyQ too. We've recently moved house and even with all settings to SD it still says subscription upgrade required.
I don't think it's the relocation as we had this problem at the old house too but as we were moving anyway I thought it would be best waiting.
