Discussion topic: Older sky minibox keeps disconnecting
This message was authored by tappa+top This message was authored by: tappa+top
My older Sky minibox keeps disconnecting at random from the main Sky Q box. It's connected to via an Ethernet cable to a mesh node. I have 2 other mini boxes that work perfectly. Tried updating the software but it keeps disconnecting.
This message was authored by oj01 This message was authored by: oj01
Re: Older sky minibox keeps disconnecting
@tappa+top Have you tried swapping the Mini Box with one of the working ones to see if the problem follows the box or stays in the location.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
tappa+top
The problem follows the minibox
Hi @tappa+top
Unless all Q boxes are connected to the same Network and by the same method a mini connected by Ethernet to a Mesh node will be unreliable (Ie unless all Q boxes are connected to mesh nodes)
tappa+top
I called Sky andthe minibox was diagonised as faulty and was exchanged for a new one.
