3
This discussion topic has been answered Discussion topic: Occasionally parts of some recorded programs are very pixelated and dialogue cuts out a lot.
This message was authored by: L.S.
I can't watch some of my recorded programs properly, because the picture and dialogue keeps cutting out. Sometimes it's throughout the program, other times most of it's okay but problems viewing now and then, whilst other recordings are perfectly fine.
Re: Occasionally parts of some recorded programs are very pixelated and dialogue cuts out a lot.
Hi @L.S.
Hi @L.S.
Avatar for L.S.
Level 0 icon
@oldfella Thank you so so much for your very swift and very clear response. I'm able to watch my recorded program now! Very much appreciated.
Avatar for L.S.
Level 0 icon
Hhhm it did work briefly but playing up again, that's wierd.
Answered - Go to Answer
