2
This discussion topic has been answered Discussion topic: Not getting satellite signal on some channels and pixilated scren on some
This message was authored by: Maureen191
As above no satellite signal on some channels
Re: Not getting satellite signal on some channels and pixilated scren on some
@Maureen191
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
@Maureen191
This message was authored by: peter-marlow+1966
Do you have any trees  near  the  satellite  dish or in front of it has these  can block the signal  to the dish, I had to have my dish  moved because  of  one tree blocking my signal, it started  with just a few channels  not getting  a signal  then as more  and more leaves came on the tree the more channels  I lost  until  they all went
P c marlow
