Discussion topic: Not connecting to Netflix
Message posted on 26 Apr 2024 02:09 PM
I am having problems connecting to Netflix, I do the usual reboot and turn off but this has been happening for weeks now and just can't seem to get on to Netflix
Message posted on 26 Apr 2024 02:27 PM
Re: Not connecting to Netflix
Are you getting any error messages or just a spinning icon on entering;
In the meantime, try refreshing your apps;
- Press Home on your Sky Q remote, then highlight Settings
- Press 0,0,1 and Select to access the Installer menu
- Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
Message posted on 26 Apr 2025 06:14 PM
I'm.having the same issue!!! Not happy!!
Message posted on 26 Apr 2025 08:29 PM
@Sue+113 wrote:I'm.having the same issue!!! Not happy!!
Have you tried the suggestions in this thread?
Message posted on 27 Apr 2025 06:20 AM
Have you tried using more exclamation marks?
What happens when you try to launch it and have you tried the suggestion in the post above?
Message posted on 27 Apr 2025 07:42 AM
No, read the thread / suggestions and decided to just watch the screen do nothing!
Yes thanks I have tried all what people suggestion
Message posted on 27 Apr 2025 07:49 AM
@Sue+113 wrote:No, read the thread / suggestions and decided to just watch the screen do nothing!
I only asked because VERY often people add to a thread without reading the rest!
Message posted on 27 Apr 2025 05:47 PM
I'm having the same issue, I find it is all streaming apps. Yet when you do the connectivity test in netflix it gets all green t icks.
Tried resetting, resetting the apps, resetting the router, restarting the apps. Every other device in the house can connect fine, 500mb internet.
Network settings on the q box says connected, then drop then reconnect.
Sky mini boxes seem to be ok but are slower.
Message posted on 27 Apr 2025 06:03 PM
Happening a lot
Several threads this week about boxes losing Internet connections
Message posted on 27 Apr 2025 06:07 PM
Well I hope they can sort, it's well annoying.
one of my mini boxes has perished this week also, so that's gonna be a fun call.
Message posted on 27 Apr 2025 06:40 PM
@jcf21 wrote:Well I hope they can sort, it's well annoying.
Just do the box troubleshooter online and it will end in a replacement without any need for a call.
Message posted on 27 Apr 2025 06:48 PM
Cool, thanks for that
