Discussion topic: Not able to connect sky q to wifi
This message was authored by: Sid1212
Following power cuts out sky q box won't connect to our WiFi.
When going into settings/network connection there is not an option to reset.
What should I do?
Re: Not able to connect sky q to wifi
What should I do?
Hi @Sid1212
