Discussion topic: None sky broadband won’t connect to sky
Message posted on 30 Sep 2023 01:39 PM
so I have gone with fibre-optic broadband because Sky couldn't provide a decent enough Internet connection. I'm now having a problem with Sky, not finding the new router
Message posted on 30 Sep 2023 01:41 PM
Re: None sky broadband won’t connect to sky
@Dan241 Do Sky provide your broadband at all? As your posts suggest they don't.
Message posted on 30 Sep 2023 06:54 PM
No, my broadband is not Sky
Message posted on 30 Sep 2023 07:01 PM
Hi @Dan241
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
