Discussion topic: None of My boxes work on more than one channel
This message was authored by: BobW2356
I am only gettimnhg one channel on my main sky Q box and the same channel on both my mini boxes. I have reset my router and reconnected the main box to the internet repaired the mini boxes and reset multiple times nothing works
Re: None of My boxes work on more than one channel
@BobW2356 can you tell us what channel you are seeing and when you try to go to another channel what happens, what do you see when you start your tv and box up ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
