Discussion topic: No volume on tV via sky
Message posted on 13 Jan 2024 08:55 AM
Hi All. All of a sudden I have no vomune through my television with sky Q. (TV Volume is fine on Netflix, apps etc) I have reset couple of times but no luck!!! Any help please.
Message posted on 13 Jan 2024 08:57 AM - last edited: 13 Jan 2024 08:57 AM
Re: No volume on tV via sky
Reset what? The remote?
edit: oh do you mean no audio at all? What audio output do you have selected in the settings?
Message posted on 13 Jan 2024 09:05 AM
I have reset the sky q box. None of the settings have changed or been touched. Sky just just has no volume coming through tV.
Message posted on 13 Jan 2024 09:41 AM
@aidanbrophy12xxx have you tried removing the HDMI cable and re-inserting it or replacing the cable or if possible try anothe TV with the box
Trying another TV would confirm whether its the box or something else
Message posted on 13 Jan 2024 09:43 AM
Even though you may get sound form other sources we sometimes find that power off restart of the TV itself cures no sound from SKY Q
Message posted on 13 Jan 2024 10:15 AM
Thank you, that's sorted it. Although now my Sky remote doesn't control the TV anymore. Tried pairing it via settings, it's says paired successfully. But it isn't working 🤷♂️
Message posted on 13 Jan 2024 10:50 AM
Try completly resetting your Bluetooth remote.
Message posted on 20 Jun 2024 05:55 PM
I've got the same problem. What was the solution that worked? Was it rebooting the TV? Or was it to do with unplugging the HDMI cable?
Message posted on 23 Jul 2024 07:32 PM
Hi Ive always had to use the TV remote for the volume so I tried the "press 4&6 then 7&9 then 1&3" and now none of the buttons work on my sky control. VERY frustrating! Can anyone help please?
