Discussion topic: No tv and broadband
This message was authored by: Summer17
No tv and broadband
Tv hasn't work since last night! Now now internet! What am I paying for ?
Re: No tv and broadband
Hi @Summer17
Have you tried rebooting your Q box?
To reconnect your Q box to the internet (that's if your broadband is still working)
