Discussion topic: No sound on sky q
This message was authored by KevinAndrea This message was authored by: KevinAndrea
No sound on sky q
Reset tv and sky q box countless time to try to fix problem.  Minibox sound is fine but absolutely silent on main box. Was perfecly fine last night
This message was authored by Quoman7 This message was authored by: Quoman7
Re: No sound on sky q
Hi @KevinAndrea Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
This message was authored by Invisiblename This message was authored by: Invisiblename
@KevinAndrea  Check that the HDMI cable is correctly seated at both the Sky Q & TV ends. Also (and apologies for this) make sure someone hasn't accidently muted the tv volume.
I am just another Sky customer!
KevinAndrea
Engineer coming out,  all the obvious checks and full reset of box made no difference.
@KevinAndrea
I am not sure if you have done it or not, but if not please may I suggest you do a full power down (i.e. switch of at mains or unplug) of your TV
We often find that such a power down of TVs restore sound - even when the TVs sound work with Freeview or inbuilt apps
