Discussion topic: No sound on any channels, went off earlier tonight and still nothing
Message posted on ‎05 Nov 2025 11:33 PM
As above. Sound cutting out , now gone off altogether, on every single channel .
Yes been unplugged twice niw and still no sound 🤬
Message posted on ‎06 Nov 2025 08:29 AM
Re: No sound on any channels, went off earlier tonight and still nothing
Hi @Qwerty1957 Try rebooting your TV first then your SKYQ box?
Message posted on ‎06 Nov 2025 03:26 PM
Already said i have done all that .
The box is less than a year old too
Message posted on ‎06 Nov 2025 03:34 PM
@Qwerty1957 wrote:Already said i have done all that .
Hi @Qwerty1957 try:-
- Press Home on your Sky Q remote, select Settings, and then Setup.
- Choose Audio Visual, then Digital audio output HDMI and make sure it's set to Normal or try Dolby Digital first if Dolby Digital Plus is already selected.
Message posted on ‎06 Nov 2025 04:50 PM
Tried all that .
Think it was Skys problem as came back 3 hours later
Message posted on ‎06 Nov 2025 11:39 PM
Dont believe it , been stuttering for ages and bloody sound gone off again.
Spend more time resetting this stuoid box than watchubg anything .
Had enough of it now.
Maybe time to cancel 🤬
Message posted on ‎07 Nov 2025 07:39 AM
Hi @Qwerty1957 Have you called SKY and reported your problem to an advisor? If so what was their answer? Have they booked an engineer visit to look at the problem?
Message posted on ‎07 Nov 2025 02:49 PM
Hi
Engineer coming Wednesday
