Discussion topic: No sound on any Sky channels or recordings,all other apps have sound. Have phoned Sky and done soft
This message was authored by: Mcfc1970
No sound on any Sky channels or recordings, all tv apps have sound.
Done software updates as recommended by Sky but still not working
Re: No sound on any Sky channels or recordings,all other apps have sound. Have phoned Sky and done s
Hi @Mcfc1970
Software update will not help if already on the latest version (Q210......).
