6
This discussion topic has been answered Discussion topic: No sound from sky q using youtube
This message was authored by: helzapoppin
Using SKY Q box I have got no sound when
i select YOUTUBE APP  other apps are working
fine.
sky q audio settings.  2160p 10bit.
digital audio output  HDMI DOLBY DIGITAL
PLUS.
connected to Sonos arc
using my Samsung tv freesat tunner I have
got sound with the YOUTUBE APP.
Avatar for helzapoppin
Level 2 icon
This message was authored by: helzapoppin Answer
Re: No sound from sky q using youtube
Updated sky q box + refreshed apps issue still there,
and then reset settings all ok now.
Level 2 icon
I have found another thread on this subject, it seems there's more
people with this issue.
Level 2 icon
This message was authored by: ekafint
I THINK THE PROBLEM IS A BUG IN THE SKY Q uhd BOXES
Sky needs to fix this issue NOW!!!
This message was authored by: Lisa6666
I have exactly the same issue! The phone engineer managed to loose all of my sound so I was stuck without any, then it just came back and youtu.be was fine for a week and now it's started going off again on YouTube! What can I do???
When my case happened, I called sky and they changed my sky Q to the 2TB box which they said did not have the problem.
Level 2 icon
since i updated my box its been working ok
