Discussion topic: No sky signal to tv
Message posted on 26 Feb 2025 07:51 PM
No sky signal to tv
Message posted on 26 Feb 2025 07:53 PM
Re: No sky signal to tv
Message posted on 26 Feb 2025 07:55 PM
@Leah20-
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
Message posted on 26 Feb 2025 08:01 PM
