Discussion topic: No sky signal for tv
Message posted on 27 May 2025 08:47 PM
I can't watch tv
Message posted on 27 May 2025 08:51 PM
Re: No sky signal for tv
@Samy-2359
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 27 May 2025 08:52 PM
No is it possible to speak to a person not a machine
Message posted on 27 May 2025 08:54 PM
I'm a customer like you. The Sky Community is a customer led discussion forum where Sky customers are available to help other customers. You are NOT contacting Sky Customer Services by posting here.
The advice provided still stands.
Message posted on 27 May 2025 09:15 PM
@Samy-2359 wrote:No is it possible to speak to a person not a machine
Yes, call them...
