Discussion topic: No sky connection no signal no channels working for last 2 weeks
This message was authored by: RUBINA10
I have been trying for two weeks to get connection there is no signal no channels are working
Re: No sky connection no signal no channels working for last 2 weeks
@RUBINA10
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
