Discussion topic: No signal
Message posted on 06 Jan 2024 12:49 PM
No signal
No signal... I've tried everything. WiFi is fine
Message posted on 06 Jan 2024 12:53 PM
Re: No signal
@Mark192
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Re: No signal
@Mark192 wrote:
No signal... I've tried everything. WiFi is fine/?
@Mark192 do you have Sky + HD Sky Q or Sky Glass/Stream ?
If you have Q or HD+ then is it no signal or no satellite signal ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
