Discussion topic: No signal - tried everything
This message was authored by: MichaelIrwin
Hi - Have no signal. in fact its been like this for many weeks but just havent plucked up teh courage to get in touch as it always takes so long to get hold of someone to convince someone to send an engineer to take a look. Please can you book me in for an engineer to come and try and problem solve. I've tried everything.
Re: No signal - tried everything
@MichaelIrwin
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
