Discussion topic: No signal to ITV 1 channel
This message was authored by: gordenbennett
Tonight I cannot get ITV 1 on as it says there is no signal and yet I can get all the other channels on?
I find it strange I am now having problems after I cancelled my Sky earlier in the week as my Son had bought me a Freesat box. However after 3 days its stopped working (no sound) so I sent it back and I phoned Sky and asked them to cancel the termination which they did and now I am having problems.
Re: No signal to ITV 1 channel
@gordenbennett
No signal or no satellite signal? They are different.
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for gordenbennett
It says no satallite signal and I have checked the leads and all seem tight. If it was a lead then I would not be able to get any other channels but they are all on including ITV2 & ITV3 its just ITV1 I cannot get.
How much does it cost for an engineer to call out?
@gordenbennett
There's no cost for a Sky engineer. If you employ a local satellite company that would be at your own expense but may be quicker. Sky wouldn't reimburse you though.
Hi @gordenbennett   I'm guessing that you may have disturbed the satellite cable connections by replacing and putting them back on the Sky Q box. I would very carefully check that the centre copper strand is not bent or damaged. Each lead provides different channels.
Which ITV1 region are you in? The way ITV is broadcast, you will also have lost either ITV2, ITV3, ITV4 or ITV Quiz depending on your region.
It won't be related to your recent decision to cancel then rejoin Sky, there's no way thay can disturb the signal to an individual customer and even if they could they wouldn't want to annoy someone who has just rejoined.
