Discussion topic: No signal on tv upstairs with any box
Message posted on 02 Feb 2024 12:56 PM
I have tried all the troubleshooting and followed the instructions on the tv but I cannot get my tv working. It says there is no signal and we reset the skybox numerous times. please advise
Message posted on 02 Feb 2024 12:59 PM
Re: No signal on tv upstairs with any box
@AndreasD A No signal message is your TV telling you there is no signal on the relevant HDMi input.
Have you scrolled through the inputs on your TV?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on 02 Feb 2024 01:09 PM
Hi @AndreasD
Reboot the minis as above.
If the minis still does not connect try a Network Reset on the mini. Start with the mini nearest to the main Q box.
When carrying out the Network on the second mini you can use WPS with the first connected mini if nearer than the main Q box.
