Discussion topic: No signal on tv upstairs with any box
This message was authored by AndreasD This message was authored by: AndreasD
I have tried all the troubleshooting and followed the instructions on the tv but I cannot get my tv working. It says there is no signal and we reset the skybox numerous times. please advise
Re: No signal on tv upstairs with any box
@AndreasD  A No signal message is your TV telling you there is no signal on the relevant HDMi input.
Have you scrolled through the inputs on your TV?
Hi @AndreasD
Reboot the minis as above.
If the minis still does not connect try a Network Reset on the mini.  Start with the mini nearest to the main Q box.
When carrying out the Network on the second mini you can use WPS with the first connected mini if nearer than the main Q box.
