Discussion topic: No signal on some channels we watch
This message was authored by: ValerieHarris
Some channels show no satellite signal, even though weather is good.
Have rebooted 3 times
Re: No signal on some channels we watch
@ValerieHarris
Rebooting won't help. If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
